14 years agoCode in architecture outside a process
Hello, i've seen in many places code in an architecture out of any process, but i can't make it work: ..... begin -------------------------------- ---- Component map -----------...
14 years agoIt would be easier to see with the actual code. But from your origional post, you cannot have if..then..else outside of a process. You will need to put a process around the code and put iteraciones, nreset and Pixelactual in the sensitivity list. You also MUST have a else case if you want to avoid latches.
