13 years agoClocking External SRAM with FPGA Output
Hi all, I'm working on a design for a Cyclone IV GX that will be using an external pipelined SRAM chip. I've been searching quite a bit, but maybe I'm using the wrong search terms; What port s...
13 years agoI guess, pipelined SRAM chip means Synchronous SRAM? Using a dedicated clock output would be the standard solution for easy timing closure, outputting the same clock that drives the RAM interface. But clock through IO pin can work as well, as long as you don't work at the SRAM speed limit. You get additional clock skew which substracts from the SRAM's timing margin.
In any case, you should constrain the SRAM interface signals according to the timing specification of the chip. If done correctly, Quartus will care for correct timing respective tell you if it can't guarantee it under the given conditions.
