13 years ago
Clock signal source should not drive registers triggered by different clock edges
I'm getting the following warning:
Warning (308022): (Medium) Rule C106: Clock signal source should not drive registers triggered by different clock edges. Found 1 node(s) related to this rule.
Its caused by a state machine clocked by the pos edge of clk and then another piece of code that needs to use the state and change a signal at the falling edge of the clock.
Should I be very concerned about this warning? From what I read, it means that it may be harder for it to meet timing, but it can work. Is there another way to accomplish changing a signal on the opposite edge of the clock (compared to when the state changes)?
    --- Quote Start ---
    I'm really new to timing constraints so I may not know what I'm doing there yet. I have attached the sdc file.
    --- Quote End ---
    You must also be fairly new to FPGA design, as your SDC indicates you are creating a lot of generated clocks. Your design sounds simple enough that one clock shoud be sufficient. Anything on a timescale shorter than that clock, eg., your serial port baud-rate generator, should be generating an enable control (pulse) for logic clocked by your main clock, not used as another clock.
    Cheers,
    Dave
