13 years agoClock signal source should not drive registers triggered by different clock edges
I'm getting the following warning:
Warning (308022): (Medium) Rule C106: Clock signal source should not drive registers triggered by different clock edges. Found 1 node(s) related to this rule. Its caused by a state machine clocked by the pos edge of clk and then another piece of code that needs to use the state and change a signal at the falling edge of the clock. Should I be very concerned about this warning? From what I read, it means that it may be harder for it to meet timing, but it can work. Is there another way to accomplish changing a signal on the opposite edge of the clock (compared to when the state changes)?
