14 years agoClock recovery from signle 125MHz pulses with PLL
Hi, I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity ...
14 years agoHi,
what do you mean by gating? I was thinking about smth like:process (clk_125_in, synchronized)
begin
if rising_edge(clk_125_in) then
if synchronized = '1' then
clock_recovery_counter <= (others => '0');
else
-- counting logic
end if;
end if;
end process;regards
