14 years agoClock recovery from signle 125MHz pulses with PLL
Hi, I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity ...
14 years agoHi kaz,
thanks, i thought about using this sync pulses to make a new "clock", let's say to invert this new clock when sync pulse occurs, that would give me me 22.05 kHz clock.... but you're right it's too slow anyway... :) perhaps i could use this new "clock" and latch the data every rising AND falling edge ? don't really know how to get the higher rates :} best regards
