14 years agoClock recovery from signle 125MHz pulses with PLL
Hi, I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity ...
14 years agoYea kaz, you're right there are not higher frequency components, sync pulses occur every 44.1kHz. Sync is exactly at 44.1 kHz.
I need to recover from that 44.1 or 88.2 or 176.4 kHz clocks. I haven't tried it yet, cause i'm doing smth else right now, i'm just asking if it's possible or there will be some problems. I would like to use a PLL module for that. best regards
