19 years agoClock Pulse Generator
Hi, I need to generate a deterministic number of clock pulses, using PLL in Stratix device. Here is what I did: PLL --> clk0 --> counter module --> clkena1 --> clk1 I developed a coun...
19 years agoI changed my clock pulse generator to feed the out to serve as clock enable for MRAM. In my design, I have 2 clock source for MRAM, as attached.
The operation sequence desired is: - sel = 0, do some configuration with using ext_clock - change sel = 1 - set start = 1. output from clock pulse generator will feed to MRAM. The number of clock pulse depends on "count" value Quartus give me a warning on gated/ripple clock at the output of clock mux. Anywhere to get rid of this? Btw, output of clock mux is promoted as global signal. With the above implementation, I am still not able to get the desired number of clock pulses. Anything wrong with my implementation? I am using Stratix I device.
