14 years agoClock problem
Hi All, I am trying to reduce the clock frequency from 25 MHZ to 12.5 MHZ using VHDL. I also intend to implement this in hardware, however I am having a lot of difficulty with my c...
14 years agoThanks you both or replying.
I was trying to eventually reduce the frequency from 25 MHZ into 1 HZ eventually so that I can output pulses that are 1 second long in duration. I thought I would start by dividing the frequency by 2 first. On the hardware I am using the 25 MHZ crystal output is converted into square waves using the NOT function. I am not entirely sure how your code divides the frequency by 2: if(clk_in'event and clk_in='1') then clk_out <= not clk_out; Thanks to you both.
