12 years agoClock Pins in Cyclone V
Hello, If I want to connect HSMA_CLK_IN_P2/N2 (which refers to CLK7p/n on my 5CSXFC6D6F31C8NES) to a PLL, I have to place the PLL in one of the two quadrants on the right of the chip, am I righ...
12 years agoFrom the 'Clock Network Sources', page 4-7:
http://www.altera.com/literature/hb/cyclone-v/cv_52004.pdf (http://www.altera.com/literature/hb/cyclone-v/cv_52004.pdf) --- Quote Start --- The CLK<#>n pins drive the PLLs over global or regional clock networks and do not have dedicated routing paths to the PLLs. --- Quote End --- If the dedicated clock pins can drive the PLLs via the global clock networks this suggests there are no restrictions as to which PLLs can be driven from any dedicated clock inputs. However, the document goes on to discuss jitter if the global or regional clock resources are used along with Altera's recommendations regarding the use of PLLs. Depending on your requirements selecting a PLL away from the edge with the dedicated clock input may or may not be appropriate. As for using a single ended clock - no, this won't gain you anything. The physical layer clock signal (differential or single ended) is terminated in the IO cell, before being driven onto a clock network. Driving a single ended clock in won't help with internal routing or choice of PLL.
