17 years agoClock Noise?
Hello, I am using a cyclone II fpga and have a 25 MHz clock going into a dedicated clock pin. I have a simple DFF to divide the clock by half to 12.5 MHz and i am looking at that output with a ...
17 years agoThank You for your quick reply's and ideas.
After further investigation i discovered the same 25Mhz clock signal was driving an Ethernet chip. That Ethernet chip was probably causing a "ring" on the clock signal. And i could not see this on an oscilloscope. I was able to cut the trace going to the chip and use an additional FPGA output to drive the Ethernet clock. This cleaned up my issues. I probably need to review Altera's design guidelines before my next project. Thanks again. ~Matt
