14 years agoclock loss detection
Hi all! Any ideas to build a fast and robust clock loss detector? A reference clock is available.
14 years agoHere is some code for discussing.
Simulation works fine, but I am not sure if there are any pitfalls.entity CLOCK_CHECK1 is
generic
gi_MAX_CNT : integer := 3
port
i_NCLR : in std_logic ; -- global /clr
i_CLK_REF : in std_logic ; -- reference clock
i_CLK_TBC : in std_logic ; -- clk 2 b checked
o_MISS_CLK : out std_logic --
end CLOCK_CHECK1 ;
architecture A_CLOCK_CHECK1 of CLOCK_CHECK1 is
signal s2_NRES_CLK_H : std_logic_vector(1 downto 0) ;
signal s2_NRES_CLK_L : std_logic_vector(1 downto 0) ;
signal si_CNT1 : integer range 0 to gi_MAX_CNT ;
begin
SYNC1: process(i_CLK_REF,i_NCLR,i_CLK_TBC)
begin
if i_NCLR = '0' or i_CLK_TBC = '0' then
s2_NRES_CLK_L <= (others => '0') ;
elsif i_CLK_REF'event and i_CLK_REF = '1' then
s2_NRES_CLK_L <= s2_NRES_CLK_L(0) & '1' ;
end if;
if i_NCLR = '0' or i_CLK_TBC = '1' then
s2_NRES_CLK_H <= (others => '0') ;
s2_NRES_CLK_H <= s2_NRES_CLK_H(0) & '1' ;
end if;
end process SYNC1;
CNT1: process(i_CLK_REF,i_NCLR,s2_NRES_CLK_H(1),s2_NRES_CLK_L(1))
begin
if i_NCLR = '0' or (s2_NRES_CLK_H(1) = '0' and s2_NRES_CLK_L(1) = '0') then
si_CNT1 <= 0 ;
if si_CNT1 < gi_MAX_CNT then
si_CNT1 <= si_CNT1 + 1 ;
end if;
end if;
end process CNT1;
REG1: process(i_CLK_REF,i_NCLR)
begin
if i_NCLR = '0' then
o_MISS_CLK <= '0' ;
if si_CNT1 = gi_MAX_CNT then
o_MISS_CLK <= '1' ;
else
o_MISS_CLK <= '0' ;
end if;
end if;
end process REG1;
end A_CLOCK_CHECK1 ;
