17 years agoclock generator
Thank you, how i do? this is a way to learn . I have a project or I do PRODUCING A synchronous clock generator using Altera CPLD max3, ie from an input clock I must have output frequencies 8kHz outpu...
17 years agoUse a counter controlled by a global (fast) clock. Compare to specific values to obtain the desired output clock frequency, and swith the low clock when this value is reached. Reset the counter at the same time and start the process again.
