RLee42
5 years agoClock generated from normal IO has a DC offset
I tried to use general IO to generate a clock for other ICs. This generated clock is from the PLL which is fed in with a crystal oscillator. When I measured this clock at the output pin, I found tha...
- 5 years ago
Is there any update from your end? I will need to close this case in 3 days if there is not respond from you.
Thank you.
AminT_Intel
5 years agoHello,
Are you using Intel FPGAs? May I know which device and what is your OPN?
AminT_Intel
5 years agoHello,
Thank you.
