18 years agoClock Buffer
Hi I have 2 verilog designs. Each of them is correct in simulation but when I simulate both of then in one schematic file, the result of simulation is incorrect. I think this problem is because of...
18 years agoHi
2 blocks are parallel and no one trrigers the other. When I simulate each of them, the result of simulation is correct. But simulation of 2 blocks in parallel cuase an incorrect answer. For example the result is not stable in positive edge of the clock and also the result is not valid after 1 period of the clock.
