16 years agoCircuit Extern DE2
Hello, i want to know if i can connect in the output of de2 a extern circuit, for example : simple circuit with resistors? Thansk
16 years agoYou can connect a 7 segment display to the GPIOs. But you should limit the current by adding a resistor in series with every LED diode of the 7 segment display. The value of the resistor depends on the amount of current Iled that you want to use for the LED. The voltage drop over your LED will be ~1.45 Volt, the logic signal from the FPGA 3.3 Volt.
There is already a 47 Ohm series resitor for every output to protect the FPGA for first order "accidents". Using Ohm's law you can calculate the resistance that you require. R = ((3.3 Volt - 1.45 Volt) / Iled) - 47 Ohm e.g. for a LED current Iled = 5 mA this boils down to: R = ((3.3 - 1.45) / 0.005) - 47 = 323 Ohm In this case you could use series resistors of 330 Ohm. It depends of course on the LEDs in the 7-segment displays how much current that should be used. There is also a limitation on the maximimum current sourcing from your FPGA pins (8 to 24 mA) depending of the I/O standard you use, as well as the combined current sourcing from consecutive pins in I/O banks. So you could use resistors of 150 Ohm.
