17 years ago
CIC Megacore
hi
i am tring to use the cic megacore from altera. but the core is just not running. i have made the following interface to it from my vhdl module:
component CIC
port( clk : IN STD_LOGIC;
clken : IN STD_LOGIC;
reset_n : IN STD_LOGIC;
in_data : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
in_valid : IN STD_LOGIC;
out_ready : IN STD_LOGIC;
in_error : IN STD_LOGIC_VECTOR (1 DOWNTO 0);
out_data : OUT STD_LOGIC_VECTOR (31 DOWNTO 0);
in_ready : OUT STD_LOGIC;
out_valid : OUT STD_LOGIC;
out_error : OUT STD_LOGIC_VECTOR (1 DOWNTO 0)
end component;
---------------------Read CIC----------------------------------
process (nreset,clk)
begin
if nreset ='1' then
out_ready<='0';
cic_out<="0000000000000000";
clken<='0';
elsif RISING_EDGE(clk) and out_valid ='1' then
clken<='0';
cic_out<=out_data;
out_ready<='1';
read_out_error<=out_error;
else
out_ready<='0';
out_ready<=out_ready;
end if;
end process;
---------------------Write CIC----------------------------------
begin
if nreset ='1' then
in_valid<='0';
in_error<="00";
elsif RISING_EDGE(clk) and in_ready ='1' then
in_valid<='1';
tempMIC8bit<="00001111";--MIC8bit;
in_error<="00";
else
in_valid<='0';
in_valid<=in_valid;
end if;
--in_valid<=in_valid;
end process;
U2:CIC PORT map (clk,clken,nreset,tempMIC8bit,in_valid,out_ready,in_error,out_data,in_ready,out_valid,out_error);
the only thing thats working is "in_ready" that goes high when i hit the reset btn :(
why is it not working? do i have to include som ekstra files? quartus has already included alot of cic files for the component.
i am using the guide from altera:
http://www.altera.com/literature/ug/ug_cic.pdf
br
benjamin
    just one point about nReset. I assume it is negative logic i.e. when '0' it resets, when '1' it is released.
    kaz
