linyag
3 years agoChip ID Reading using AVST Mailbox IP in Agilex
hi, We are debugging the acceleration board of agilex and want to get the chip id of the board. But when adding Mailbox IP to the project, many errors occurred in the synthesis. Our project can...
KellyJialin_Goh
3 years agoHi,
For using the Mail Box IP, Signal tap has to be running and connected on Quartus. The documentation can be found on how to run signal tap on the left upper corner here for your reference: https://www.intel.com/content/www/us/en/design-example/763981/intel-agilex-7-fpga-chip-id-reading-using-avst-mailbox-ip.html
Hope this clear your doubts.
Thank you.
Kelly
- linyag3 years ago
In the manual of the mailbox, we can’t find that the chip id must be read through the Signal tap.
In addition, there are other ways to read the chip id for the agilex chip (without using the Signal tap, the user logic obtains the chip id like A10)?
thanks
linyag
