linyag
3 years agoChip ID Reading using AVST Mailbox IP in Agilex
hi, We are debugging the acceleration board of agilex and want to get the chip id of the board. But when adding Mailbox IP to the project, many errors occurred in the synthesis. Our project can...
KellyJialin_Goh
3 years agoHi,
Greetings and welcome to Intel's forum.
We have a design example for chip ID reading using AVST Mailbox IP for your reference. You may use this design example to see if the error is eliminated: https://www.intel.com/content/www/us/en/design-example/763981/intel-agilex-7-fpga-chip-id-reading-using-avst-mailbox-ip.html
Thank you.
Kelly Jialin, GOH
- linyag3 years ago
The reference is exactly this example, the difference is that the Signal Tap will be used in the example, but the signal tap is turned off in our static. Mailbox IP must need a signal tap?
thanks
