Checking lifecycle status of EPM3064ATC100-10N
- 3 years ago
Check this thread: https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Drop-in-Replacement/m-p/1209795
And this thread: https://community.intel.com/t5/Programmable-Devices/Altera-MAX3000-series/td-p/713684
The MAX3000 series went EOL back in 2018.
No direct replacements from Intel/Altera.
You might check on the Microchip ATF1500 series parts there may be a size/package combo you can use.
If I read the datasheet correctly, the ATF1504ASV-15AU100 should be a drop in replacement for the EPM3064ATC100-10.
The only difference is in the speed grade rating of 15ns vs 10ns. So depending on your application requirement, YMMV.
You can use their POF2JED program to convert your Intel/Altera .pof file to a .jed file to program the Microchip/Atmel.
Nazrul Naim, Yes we are on working with that and thanks for the support , Hence we are closing the issue.
