16 years agoChanging frequency of the system
Hi I was interested in knowing if there is any way in which I could change the frequencies that various components on my FPGA ran at, without actually going through the entire synthesis process. T...
16 years ago --- Quote Start --- Thanks a lot for the Reconfigurable pll suggestion, will check it out. Seems ideal for my requirements :) @Pletz The clock frequencies would vary by about +-20% of nominal values for instance , and the design would have around 3 to 4 tunable clocks. I am trying to emulate a multiple frequency based design which communicates via FIFO's and want to measure system performance as a function of different frequencies. --- Quote End --- Hi, you should follow FvM suggestions. Kind regards GPK
