16 years agoChanging frequency of the system
Hi I was interested in knowing if there is any way in which I could change the frequencies that various components on my FPGA ran at, without actually going through the entire synthesis process. T...
16 years agoThere are various options to achieve what you intend. The most comfortable solution is to add an ALTPLL_RECONFIG Megafunction (if supported by the respective FPGA family) and control the parameter e.g. by a Source and Probe instance. A more basic method is to edit the PLL parameters by the Chip Editor and perform the fairly fast Engineering Change flow, that involves only part of the fitter. I used the method to evaluate the clock phase for LVDS SERDES.
