changing C code run time with changing variable name in NIOS Eclipse
Hi, Taha
It depends on where you store the variable, the run time may be longer for external RAM, and shorter for internal RAM.
Also, a long int type may take longer run time than int.
As long as the variable follows the naming rule, it shouldn't affect the run time.
Eric
thanks for replying sir,
i have a system that include 2 nios processor which are connected the same sdram memory (assigning spesific address range) and a dual port internal ram for transferring data (for the data communication) . i am writing a data from 1st nios to 2nd nios. for1st nios to 2nd nios, if i assign an int variable with name a, data sending run time is 10 ms. if i name it 'a11' sending run time is being 8 ms. so i am writing the data on the same ram address with different name and run time is chaging like this.
