change the slew rate to medium MAX V
- 2 years ago
1. pin planner doesn't display all available pin option by default. Use "customize columns" in context menu to display "Slow Slew Rate" option.
2. The tcl command is
set_instance_assignment -name SLOW_SLEW_RATE ON to <pin name>
There's no "medium" slew rate setting. You can set "slow slew rate" for individual pins, default setting is off. Review resource section, output pins in fitter report in case of doubt.
- Vitali12 years ago
thank you!
