10 years agochange the default program on a max 10
Hi all,
I'm looking for a tutorial to change the default program on the FPGA(max10) while you plug it. thk you2 Replies
Thks Alex, is configuring flash memory includes programming the nios too, or there another method to do it ?
See the 'max 10 fpga configuration user guide (https://www.altera.com/literature/hb/max-10/ug_m10_config.pdf)'. To "change the default program on the FPGA(max10) while you plug it" you need to re-program its Configuration Flash Memory (CFM). See chapter 2 in the above document.
Cheers, Alex
