10 years agochange the default program on a max 10
Hi all, I'm looking for a tutorial to change the default program on the FPGA(max10) while you plug it. thk you
10 years agoSee the 'max 10 fpga configuration user guide (https://www.altera.com/literature/hb/max-10/ug_m10_config.pdf)'. To "change the default program on the FPGA(max10) while you plug it" you need to re-program its Configuration Flash Memory (CFM). See chapter 2 in the above document.
Cheers, Alex
