10 years agoCFI Flash programming error
I'm trying to program CFI Flash Device 512mb Intel stratra through the CPLD system controller that is Parallel Flash Loader IP (PFL). All the time I have the same error message:error (209025): can't recognize silicon id for device 2
error (209012): operation failed
i checked all cpld pins to be set as tri state. i also checked all the signals to be connected correctly.
does anybody know what the problem is?
thank you in advance!
nome
--- Quote Start --- Hello Can anyone who have give me answer of my above post Still i am waiting Thanks Nome --- Quote End --- Sorry i cant help you that. but can you tell me how to check all cpld pins to be set as tri state? i have the same error, thank you! - Altera_Forum
Hello
Can anyone who have give me answer of my above post Still i am waiting Thanks Nome - Altera_Forum
Hello Schmalish
Thanks for your Reply As per page 33 to 34 in the Parallel Flash Loader IP Core User Guide i have added all parameters as per datasheet and my new database flash name is CFI_intel512 . but when i go to Attach Flash Device there is no new database as we added before in Define CFI Flash Device. i do not know how to add our new database CFI Flash CFI_intel512. i am using Quartus prime standart edition 15.1.0 Run as Administrator kindly help us where i am wrong Thanks Nome - Altera_Forum
most likely the flash device you are using is not in the database and you have to add it as a new CFI Flash Device, see page 33 to 34 in the parallel flash loader ip core user guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_pfl.pdf).
