14 years agoCascading CPLDs on different PCBs
I'm designing a basic harness continuity checker based on shift registers implemented in Max V CPLDs. I'm aiming for a modular/extendable PCB design for the project as it has several benefits (cost, ...
14 years agoDave,
You mentioned that I should have an external oscillator on the board that feeds the global clock network of the CPLDs via the GCLK pins. My questions are: 1) Do I need to connect the oscillator to all 4 pins? The development board's schematic shows the oscillator being only connected to one pin. 2) What's the best way to send this clock source to the next PCB? LVDS I presume? I'm gonna go with a oscillator of 8 MHz or so. 3) Is it better to go with an oscillator or a crystal?
