14 years agoCascading CPLDs on different PCBs
I'm designing a basic harness continuity checker based on shift registers implemented in Max V CPLDs. I'm aiming for a modular/extendable PCB design for the project as it has several benefits (cost, ...
14 years agoI didn't realize the LSB is hard-wired. Of course it is, otherwise we'd need two switches. Sometimes I miss obvious things - sorry about that.
I'M now thinking of the format of an entire frame. Each module will have 74 test points. Let's assume it's just 72 bits and we get a nice round figure of 9 bytes. So, we first send 2-bytes containing the address and then we send 9 bytes of data - obviously if the address doesn't match, the CPLD ignores anything sent afterwards. So essentially we have a 11 byte shift register. The CPLD, after receiving all 9 bytes of data can enable the outputs so that the test-vector appears at the output. This seems simple enough. The CPLD can transfer the data to another shift-register thats only meant for the output test-vector. However, how would the uC receive back the data from the CPLDs that specifically are meant for receiving the test-vectors? How about if I make the address 15-bit and make the LSB a Read/Write indicator? If this is 0, the CPLD will send the 9 bytes of data in its shift register. If it's 1, it will shift in new data that it receives just after this Read/Write bit. I know this is probably inefficient but I'm trying to start out small. As the devices will have a full SPI interface, I can easily upgrade the firmware as I get more experience with VHDL. I've been a C programmer for the past 10 years so VHDL still runs circles around my head.
