17 years agoCapture the falling edge of signals in VHDL
Hi, Please bear me with a newbie's question: I want to capture a PWM signal's falling edge. But, I can not use "falling_edge" as the PWM signal is not a clock signal. Can any exper...
17 years agohi,
maybe you should sample your pwm signal with a clk. every clk's rising edge check the pwm signal state (in the process you need a last state variable, to know the pwm's last state). if there is a change - there was a edge in the pwm signal. some thing like that... process(clk) variable last_state: std_logic := '0'; begin if clk='1' and clk'event then --if last_state = '0' and pwm_signal = '1' then --rising edge if last_state = '1' and pwm_signal = '0' then --falling edge -- pwm edge end if; last_state := pwm_signal; end if; end process; your clk must be fast enough to detect edges ;) hope it helps! have a nice day joerg
