13 years ago
Can't get my do while loop to repeat
Here is a sample of my code, I'm trying to make a prompt for a user enter 1 for reset test, 2 to do something later, and 3 to exit. After pressing 1 the reset code executes, the code should then reask the user to input 1, 2 or 3; only after pressing 3 should the code exit. The reset code executes perfectly, but I can't get the prompt to repeat. My variable 'c' is declared as int, and 'quit' is declared as u8. I wanted to declare 'quit' as bool or boolean, but my compiler didn't recognize bool.
do
c=0;
TestFailed = 0;
TestSuccess = 0;
alt_printf("Enter 1 for reset test, 2 for ???, and 3 to exit");
c = alt_getchar();
alt_printf("You chose %s\n", c);
switch(c)
case '1':
alt_printf("Reset Test\n");
alt_printf("Entering reset loop with %x resets. \n", num_results);
for (ii = 0; ii < num_resets; ii++)
//Reset the core through reg read mod write to bit 4.
iprop_dev_portreset((u32*)DEV_BUS_SLAVE_BASE);
//poll on bit 5 of ADI_DEV_CORE_STATUS every 1 ms for when device is up and running timeout after 20ms
rc = iprop_wait_reg((u32*)(DEV_BUS_SLAVE_BASE + ADI_OFFSET + ADI_DEV_CORE_STATUS),
0x20, //only look at bit 5
0x00, //if bit-1 ==1, we're phy-ready
1, //wait 1us between register reads
100000); //~100ms
read = Iprop_RegRead32((u32*)DEV_BUS_SLAVE_BASE, ADI_OFFSET + ADI_DEV_CORE_STATUS);
if ((rc & 0x20) == DEV_STATUS_PHYRDY)
TestSuccess = TestSuccess + 1;
else
TestFailed = TestFailed + 1;
//sleep to allow the drive to send an initial d2h
percent_done = ii/(num_resets/10);
if (ii%(num_resets/10) == 0)
alt_printf("%x0%% Done\n", percent_done);
usleep(10);
alt_printf("Test Completed\n");
alt_printf("Successful Results: %x ", TestSucccess);
alt_printf("Failed Resets: %x ", TestFailed);
while(1)
return 0;
break;
case '2':
alt_printf("???");
while(1)
return 0;
break;
case '3':
alt_printf("Exiting");
quit = 0xFF;
while(1)
return 0;
break;
default:
alt_printf("Invalid entry %s", c);
while(1)
return 0;
break;
}while (!quit);
    These are the silly mistakes that we make and get stuck in the middle.
    --- Quote Start ---
    do
    c=0;
    TestFailed = 0;
    TestSuccess = 0;
    c = alt_getchar();
    switch(c)
    case '1':
    100000); //~100ms
    else
    usleep(10);
    while(1)
    return 0;
    break;
    case '2':
    alt_printf("???");
    while(1)
    return 0;
    break;
    case '3':
    quit = 0xFF;
    while(1)
    return 0;
    break;
    default:
    while(1)
    return 0;
    break;
    }while (!quit);
    --- Quote End ---
    Nevermind, I just had to take out the while loops at the end of my case statements. Of course!
