14 years agocan't find the reason Stratix IV GX short-circuited between VCC and GND
hello everyone: i have some questions about Stratix IV GX the first time we configurate the FPGA in jtag, it's display configurate failed at 90%。We check the pcb and find that three pull-...
14 years ago --- Quote Start --- i remove the bead,and find it is ok about the power supply.the output voltage is 1.496V. Both Vccpt and Vccio (BANK7 and BANK8) is using the same PTH0510w,but there is nothing wrong of Vccio (BANK7 and BANK8) . what i can't understand is Vccio(BANK7 and BANK8) is ok, whlie Vccpt is short-circuited with GND, if there is something wrong of the power supply(PTH0510w). --- Quote End --- If I understand your description; you have removed the bead to VCCPT and powered the board, and VCCIO is correctly powered. If that is the case, then the power supply is fine. The problem is related to the VCCPT on the FPGA. --- Quote Start --- And what i want to know is if there is something wrong about the FPGA itself,before the first configuration.it's so expensive,and should not be so fragile. --- Quote End --- It does sound like the FPGA has been damaged in some way. Could you please measure the power-on waveforms from the power controller. Perhaps it has some over-shoot on startup that exceeds the maximum voltage of the VCCPT power rail (as FvM suggested). The problem with using a power module is that you have no control of the controller feedback loop. If you have put too much capacitance on the supply output, you may have changed the controller loop dynamics. Did you follow the power module recommendations for decoupling, or use more? Cheers, Dave
