pivengineer
2 years agoCan't Debug Nios V on CL10 LP
Hello, I am working on trying to implement a Nios V system on a CL10LP SOM from Aries Embedded. I have tried using the Nios V for Arria 10 tutorial as a guide in addition I examined the example with...
AnnC_Altera
2 years agoHi,
What did you do when you encountered the debugger error?
Can you share below information when you try to connect the kit where the sof has been programmed sucessfully?
Thank you,
Ann
