9 years agoCan't close timing on one clock domain
Hi, I've been struggling to close timing on one clock domain in my design, happens to be the one with all my control logic/ nios on it so is kind of important for getting into functional test....
9 years agoOne big issue I see is that your report indicates that a burst adapter is getting added into your Qsys system design which adds a large amount of combinatorial delay into the interconnect. There's a number of possible reasons for this.
Data path (master / slave) width mismatch Either master or slave can use a burst and have a burst count field on Avalon interface When master is bursting to a slave and there’s a data width mismatch Matching data path width but different burst counts Burst count fields in the master and slave may be different widths Master with narrower burst count width than slave: not usually a problem Slave has narrower burst count width than master: adapter needed to split burst into smaller bursts; should be resolved if possible Burst type not supported by slave Example: AXI master bursting to an Avalon slave Solutions: match burst widths if possible or use a pipeline bridge component, matching the burst widths on either side of the bridge. So if you have a burst width of 8 from a master and slaves only support a burst of 1, add a pipeline bridge between the master and slaves with a width of 8 on its slave side and a width of 1 on its master side. You can also add pipeline stages inside the interconnect on the Interconnect Requirements window in Qsys or manually in the Show System with Qsys Interconnect option from the Qsys System menu.
