16 years agocan't boot from sram
I build sopc with epcs component, with the reset vector and exception vector at sram section, and set .text section at sram section, I have changed the sram width from 32 bit to 8 bit, but I still ca...
16 years agoIn theory you should be able to flash them separately, as long as the two generated .flash files were made from the same .sof source (and with the same settings, especially compression for the hardware image). But I'm glad you found a way that works ;)
