16 years agocan't boot from sram
I build sopc with epcs component, with the reset vector and exception vector at sram section, and set .text section at sram section, I have changed the sram width from 32 bit to 8 bit, but I still ca...
16 years agothe "sof" flash is just used to know where to place the elf application in the EPCS. It should be placed right after the hardware configuration.
I find the mathed they describe a bit complicated... Using the Nios programmer you can directly write both .flash files in the EPCS.
