16 years agocan't boot from sram
I build sopc with epcs component, with the reset vector and exception vector at sram section, and set .text section at sram section, I have changed the sram width from 32 bit to 8 bit, but I still ca...
16 years agoHi Sailor!
Are you programming your EPCS with the software (and hardware, for that matter) after setting the reset vector there? That's what must be done with EPCS or CFI (serial and parallel) flash devices. After that everything should work. Cheers, --slacker
