18 years agoCannot generate .sof file for CPLD
I've built a simple test project for some new hardware using a MAX II CPLD, but I can't get it to generate a .sof file for programming the device, all I get is a .pof file which isn't any use (I'm using a USB Blaster). Can someone please point out where I'm going wrong.
Leon4 Replies
I was also confused by the JTAG not working, I subsequently found that I'd assembled the MAX II the wrong way round. 8-(
Leon - Altera_Forum
Thanks. I'm more used to the FPGAs and it's a long time since I've used an Altera CPLD.
Leon - Altera_Forum
--- Quote Start --- all I get is a .pof file which isn't any use --- Quote End --- You apparently didn't try to simply program the pof file to the MAX II device. You'll find out that Quartus programmer accepts pof files only for CPLD devices. - Altera_Forum
the .pof file is the correct file for programming CPLD.
.sof files are only for SRAM based devices. regards
