Cannot assign clock signal to XCVR bank pin - Arria 10
Hello FvM,
I used the "Transceiver Native PHY Intel Arria 10/Cyclone 10 FPGA IP" for generating clock signal, the data part should not be a problem to generate output serialized signal as you mentionned. However it doesn't appear very clear to me what clock(s) I should assign to this IP. Here are some details :
I have to supply 2 clock inputs to the transceiver , and - I suppose - to its CGB, which are :
- tx_serial_clk0
- tx_coreclkin
I saw from the IP datasheet that coreclkin frequency should be ( Datarate / (parallel_data) ) which is 1GBPS / 8bits = 125 MHz.
It is also mentionned in the picture above that the "TX PLL IP" must provide a clock frequency of 500 MHz related to internal clock division factor. I couldn't find more detail in datasheet to explain if this clock is the serial or core one, which is a bit confusing.
Anyway, the way I assigned clocks, and corresponding to Arria 10 pins, is the following :
- reference_clk from FPGA core (CLK_50_B2H - 50 MHz) -> IOPLL (125 MHz) -> tx_coreclkin
- reference_clk_from_FPGA core (CLK_50_B3H - 50 MHz) -> fPLL (500 MHz) -> tx_serial_clk0
The compilation fails during fitter. I also used dedicated transceiver reference clock CLKUSR_100 for the fPLL instead of the 50 MHz user clock, and I have in any case same error which is :
Input port "REFCLK" of "CMU_FPLL_REFCLK_SELECT" cannot connect to PLD port "O" of "IO_INPUT_BUFFER" for node "CLKUSR_100~input".
What is strange is that it shows here an error related to fPLL reference clock, while when I remove the Transceiver IP, the compilation is successful. So I guess it is rather related to Transceiver reference clocking rather than fPLL reference clocking ?
I would be grateful if you could enlighten me on this !
- Rleduc3 years ago
Problem solved, on HAN Pilot Plateform, the serial output I use is SFP connector, which also has its dedicated reference clock SFP_REFLCLK_p of 644,53125 MHz.
Thank you for previous answers anyway
