Sathvika
2 years agoCan we use 5M40ZE64 instead of 5M80ZE64
I am making a design with 10M08DAF484C8GES FPGA, and in the schematic file I see there is a CPLD 5M80ZE64. But it is out of stock. So instead shall I use 5M40ZE64. My use cases are: (i) Loading th...
- 2 years ago
Ok got it. Thanks for your response.
Farabi_Altera
2 years agoHello,
To design and program MAX10 FPGA device you dont need MAXV. MAX10 capable to accept the JTAG connection from USB Blaster II programming cable(separate purchase).
The MAXV you see on the devkit contains the embedded USB Blaster II image itself, so you dont need to buy a separate USB Blaster II programming cable. You can purchase this IP from Intel Sales reps but it is not cheap. If you making >1000pcs of boards it will worth buying the IP. If not, we recommend just use the USB Blaster II programming cable.
regards,
Farabi
