Sathvika
2 years agoCan we use 5M40ZE64 instead of 5M80ZE64
I am making a design with 10M08DAF484C8GES FPGA, and in the schematic file I see there is a CPLD 5M80ZE64. But it is out of stock. So instead shall I use 5M40ZE64. My use cases are: (i) Loading th...
- 2 years ago
Ok got it. Thanks for your response.
_AK6DN_
2 years agoDo you have the source design file for the MAX V 5M80ZE64 part?
If so, just change the target device and recompile and see if it fits in a device that is half the size.
The 5M80ZE64 and 5M40ZE64 parts will require different programming image files, so you will need the source to recompile.
- Sathvika2 years ago
I currently don't have the source design file. But the problem is, we have not ordered 5M40ZE64 also because we are still designing the schematic. So currently I have no source to re compile and check. Before I give my schematic board for fabrication, I wanted to check if we could use 5M40ZE64.
