16 years agocan UART be control using VHDL coding
can UART be assigned by using the VHDL coding. cause i am working on a stepper motor control n taught of using UART
16 years agoentity uart is
port ( reset :in std_logic; txclk :in std_logic; ld_tx_data :in std_logic; tx_data :in std_logic_vector (7 downto 0); tx_enable :in std_logic; tx_out :out std_logic; tx_empty :out std_logic; rxclk :in std_logic; uld_rx_data :in std_logic; rx_data :out std_logic_vector (7 downto 0); rx_enable :in std_logic; rx_in :in std_logic; rx_empty :out std_logic ); end entity; architecture rtl of uart is -- Internal Variables signal tx_reg :std_logic_vector (7 downto 0); signal tx_over_run :std_logic; signal tx_cnt :std_logic_vector (3 downto 0); signal rx_reg :std_logic_vector (7 downto 0); signal rx_sample_cnt :std_logic_vector (3 downto 0); signal rx_cnt :std_logic_vector (3 downto 0); signal rx_frame_err :std_logic; signal rx_over_run :std_logic; signal rx_d1 :std_logic; signal rx_d2 :std_logic; signal rx_busy :std_logic; signal rx_is_empty :std_logic; signal tx_is_empty :std_logic; begin -- UART RX Logic process (rxclk, reset) begin if (reset = '1') then rx_reg <= (others=>'0'); rx_data <= (others=>'0'); rx_sample_cnt <= (others=>'0'); rx_cnt <= (others=>'0'); rx_frame_err <= '0'; rx_over_run <= '0'; rx_is_empty <= '1'; rx_d1 <= '1'; rx_d2 <= '1'; rx_busy <= '0'; elsif (rising_edge(rxclk)) then -- Synchronize the asynch signal rx_d1 <= rx_in; rx_d2 <= rx_d1; -- Uload the rx data if (uld_rx_data = '1') then rx_data <= rx_reg; rx_is_empty <= '1'; end if; -- Receive data only when rx is enabled if (rx_enable = '1') then -- Check if just received start of frame if (rx_busy = '0' and rx_d2 = '0') then rx_busy <= '1'; rx_sample_cnt <= X"1"; rx_cnt <= X"0"; end if; -- Start of frame detected, Proceed with rest of data if (rx_busy = '1') then rx_sample_cnt <= rx_sample_cnt + 1; -- Logic to sample at middle of data if (rx_sample_cnt = 7) then if ((rx_d2 = '1') and (rx_cnt = 0)) then rx_busy <= '0'; else rx_cnt <= rx_cnt + 1; -- Start storing the rx data if (rx_cnt > 0 and rx_cnt < 9) then rx_reg(conv_integer(rx_cnt) - 1) <= rx_d2; end if; if (rx_cnt = 9) then rx_busy <= '0'; -- Check if End of frame received correctly if (rx_d2 = '0') then rx_frame_err <= '1'; else rx_is_empty <= '0'; rx_frame_err <= '0'; -- Check if last rx data was not unloaded, if (rx_is_empty = '1') then rx_over_run <= '0'; else rx_over_run <= '1'; end if; end if; end if; end if; end if; end if; end if; if (rx_enable = '0') then rx_busy <= '0'; end if; end if; end process; rx_empty <= rx_is_empty; -- UART TX Logic process (txclk, reset) begin if (reset = '1') then tx_reg <= (others=>'0'); tx_is_empty <= '1'; tx_over_run <= '0'; tx_out <= '1'; tx_cnt <= (others=>'0'); elsif (rising_edge(txclk)) then if (ld_tx_data = '1') then if (tx_is_empty = '0') then tx_over_run <= '0'; else tx_reg <= tx_data; tx_is_empty <= '0'; end if; end if; if (tx_enable = '1' and tx_is_empty = '0') then tx_cnt <= tx_cnt + 1; if (tx_cnt = 0) then tx_out <= '0'; end if; if (tx_cnt > 0 and tx_cnt < 9) then tx_out <= tx_reg(conv_integer(tx_cnt) -1); end if; if (tx_cnt = 9) then tx_out <= '1'; tx_cnt <= X"0"; tx_is_empty <= '1'; end if; end if; if (tx_enable = '0') then tx_cnt <= X"0"; end if; end if; end process; tx_empty <= tx_is_empty; end architecture;
