16 years agocan UART be control using VHDL coding
can UART be assigned by using the VHDL coding. cause i am working on a stepper motor control n taught of using UART
16 years agomy exact problem is i need to communicate between the normal vhdl code, which i use to generate pulse n transfer the pulse into the uart port to run my stepper motor.
