17 years agoCan the TX of Transceiver-A be routed to the RX of Transceiver-B internal to the FPGA
Hello, This question is for both the Stratix II GX High Speed Serial Transceivers and the Stratix IV GX High Speed Serial Transceivers Can the TX of Transceiver-A be routed to the RX of ...
17 years agoDoesn't the loopback feature only work within a single transceiver? What I want to do is go from one transceiver's TX to different tranceivers's RX inside the FPGA so that I can intercept the signal between the two with some programmable logic.
Is that possible? Thanks again.
