8 years agoCan one board support an Arria 10 GX *or* an Arria 10 SX?
I've looked at the vertical migration between Arria 10GX parts and I'm wondering if there is anything stopping someone from making a board that can also support an SX part. When I put the two pin-...
8 years agoHi Bgrattan, Do you want to use same board for both GX & SX device using socket? if yes than Check whether configuration/dedicated pins are in same location.(For pick and place). If you have soc project build on Arria 10 SX it may not work (depends on IP) so take care in IP's . While designing a board, bring those two dozen trace on top layer. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
