11 years agoCan not implement the requested PLL: VCO or PFD frequency range exceeded
Hello, I need to scale 3.58 MHz 16 times up, to 57.28 MHz. EP3C5 device. Minimum frequency I put to clear the error is 5 MHz. I created project from the scratch, does it need some default settin...
11 years agoI think you will need the clock generator. It is a simple solution to your problem and a peace of mind.
You will need to meet the min 5Mhz spec.
