11 years agoCan not implement the requested PLL: VCO or PFD frequency range exceeded
Hello, I need to scale 3.58 MHz 16 times up, to 57.28 MHz. EP3C5 device. Minimum frequency I put to clear the error is 5 MHz. I created project from the scratch, does it need some default settin...
11 years ago --- Quote Start --- Pete, thank you very much. You explanation is clear. My design has only one, slow clock, which I wanted to scale up. The intention of my question was to know if it is ever possible to feed PLL with such slow clock (e.g. changing some PLL or chip-level settings) properly. If you confirm it is not possible in any circumstances, then I will just add the clock generator to the board - I still have this option because board is not yet finalized. --- Quote End --- With the cyclone III family (and IV, V and Max 10 families for that matter) the PLL datasheet fin minimum is stated at 5 MHz. Is it possible to make PLL's that lock to frequencies < 5 MHz, yes, But the PLL's in the Cyclone fabric were designed with a 5 MHz minimum frequency target. Will it work at 3.58 MHz input? Possible, but it won't be guaranteed, and a lock output may not be stable. To try it you would have to setup your 16x multiplication as if you input clock was 5 MHz, and just run it with a 3.58 MHz source and run it and see. But even if it works at room temperature, it may not work at the hot/cold corners. Pete
