17 years agoCan not dowload the code into my Altera
I met a weird problem: I can download the code into my Altera chip EPM240T100 comfortably at the first time. But, I can not download the code again. The errors are: Error: Can't access JTAG cha...
17 years ago --- Quote Start --- The LED driving pin was set as output pin "driving unspecified signals". It is a used pin instead of "unused" pin. I tested in the board without cutting any connections while setting the "All unused reserved pins" as "Input tri-stated with weak pull-up resistor". Then, I could load the code into the board but LED could not be lit anymore.... --- Quote End --- Hi, is the pin driven by your design ? Kind Regards GPK
