17 years agoCan not dowload the code into my Altera
I met a weird problem: I can download the code into my Altera chip EPM240T100 comfortably at the first time. But, I can not download the code again. The errors are: Error: Can't access JTAG cha...
17 years ago --- Quote Start --- It is a "home-made" board.... --- Quote End --- OK, can you describe what is on the board ? BTW you should check the power supply when the Altera device is loaded. Kind regards GPK
