12 years agoCan I use EPCQ32 with Cyclone III?
Hello, I mistakenly used an EPCS16 (8-pin SOIC) in my design with a Cyclone III EP3C120. Active serial has been working but if I use more than half the chip then my program will probably not fit ...
11 years ago"Disable EPCS ID Check" is only for configuration purpose.Cyclone II and other older devices (prior to V series) cant recognized EPCQ device ID when this EPCQ is sending data to the FPGA.Thats why disabling the option solved the issue. If used with <EPCS128, there is no need to disable it. Note that Cyclone II was developed long time ago before the EPCQs.
